Pully problem
Old Aug 23, 2008 | 10:52 PM
gtfla2's Avatar
gtfla2
Default Pully problem
Okay I had bbk under drive pulleys on my car and I kept getting check engine light so I re torqued the crank pulley then my car start squiling and would feel boggy at low rpm really bad then it would be almost normal at high rpms. I put my stock pulleys back on and the same problem is happening the car act really boggy down low like it doesn't want to move then when it reaches high rpm it back normal and o yea I did buy a new crank pulley bolt.
Old Aug 23, 2008 | 10:56 PM
jwog666's Avatar
jwog666
what was the code that set the check engine light?
Old Aug 24, 2008 | 11:08 AM
gtfla2's Avatar
gtfla2
The car is a 1996 gt. plus the code was for the knock sensor
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ctgreddy
Sep 20, 2015 08:35 PM
