question about camshafts
Old May 16, 2005 | 12:31 AM
walsher's Avatar
walsher
Default question about camshafts
Are the 87-93 5.0 camshafts the same as the 94-95 cams? are they identical or slight differences.
Old May 16, 2005 | 01:49 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: question about camshafts
Its the same engine so I don't see why it wouldn't work.
Old May 16, 2005 | 03:10 AM
tyybo's Avatar
tyybo
wouldnt the heads have a differnt design? When did ford go to EFI in the GT?
Old May 16, 2005 | 09:22 AM
Djs94stang's Avatar
Djs94stang
Efi was 1986...
Old May 16, 2005 | 09:23 AM
Djs94stang's Avatar
Djs94stang
The grind may be different on the 94-95's but otherwise it's the same.
Old May 16, 2005 | 12:23 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
They will fit but the grind is slighlty different I believe. But my main question is why? If you are going to put a cam in get one that will match the rest of your mods and give you more power.
Old May 16, 2005 | 04:36 PM
MustangChuck's Avatar
MustangChuck
I am pretty sure they are the same -- Ford Engineering number E8ZE-6250-CA.
Chuck Martin
MustangChuck
Old May 16, 2005 | 08:10 PM
walsher's Avatar
walsher
well im doing an HO conversion on my 89 Lincoln towncar, and i know the 87-93 will fit, but nothing more aggressive. So if the 94-95 is any more aggressive, it would cause serious piston to valve clearance issues b/c my pistons do not have valve reliefs.
Old May 16, 2005 | 09:42 PM
JD1969's Avatar
JD1969
Makes sence, I see where you are going with it.
Old Apr 12, 2009 | 12:26 PM
NO9FKB95COBRA's Avatar
NO9FKB95COBRA
What is the biggest cam you can put in a '95 5.0 Cobra W/ Factory '95 cobra heads
I need to know what cam works best. Ported Cobra intake, heads, bigger throttle body, and 5speed. I heard .512" lift is the max you can go w/out clearance problems and am thinking about the Ford Racing f-303 cam. My Pistons are Factory, rockers, everythin is factory, but it wont be soon.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
NYstang
Sep 30, 2015 09:56 PM
