torquing struts and shocks
Old Sep 18, 2008 | 08:47 AM
vancebreck's Avatar
vancebreck
Default torquing struts and shocks
I just finished installing my Tokico D-Spec shocks and struts a few days ago, but I had some problems torquing the retaining nuts to the proper specs. I would ratchet and ratchet and ratchet but the wrench would never "pop". Finally I took a few turns with a box wrench and what I found was the strut/shock shafts were turning with the retaining nut. I abandoned the torque wrench and used two box wrenches to tighten the nuts as best I could.
Anybody else have this problem? I can't figure out how to torque the nuts I am unable to use the wrench.
Old Sep 18, 2008 | 11:26 AM
.boB's Avatar
.boB
You can use a crow foot on your torque wrench. It changes the reading though, you have to compensate for the additional leverage. Somewhere I had the formula, but I can't find it.
Old Sep 19, 2008 | 10:46 PM
Jfsram's Avatar
Jfsram
A couple quick blasts with an impact gun.
The hits will turn the nut, a bit at a time. While hopefully the rod doesn't spin.
Old Sep 19, 2008 | 11:04 PM
OnyxCobra's Avatar
OnyxCobra
bad idea, do NOT use an impact to tighten the struts. Use the open end wrenches and get them fairly tight, check them again after a little driving to make sure they aren't loosening. Just don't over tighten them.
Old Sep 22, 2008 | 05:11 AM
Jfsram's Avatar
Jfsram
Yes, you are correct. It is a bad idea for amatuers to use impact tools for assembling.
For that matter the only accepted tool is a torque wrench.
But if you have a feel for these things, which you will after swapping out many pairs of struts. A quick blast of an impact gun will turn the nut without turning the rod.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
