Anti-lock Light Problem (Relay)
Old Oct 1, 2008 | 06:00 PM
theblackmages's Avatar
theblackmages
Default Anti-lock Light Problem (Relay)
Hey, I'm new here and I must say this is a nice Forum.
I recently bought a 1994 Ford mustang V6 with a standart tranny. It's imported from Ontario so I need to pass the state inspection.
The Anti-Lock light stays on, so I decided to plug it to a scanner and what it says is that the ABS Relay is at fault. I don't have the owners manual so I can't locate the Anti-Lock Relay.
Does anyone have the code for the Anti-Lock relay, or a ford's owner manual for this car?
Thanks, Jeff.
Old Oct 2, 2008 | 06:02 PM
theblackmages
Where is the ABS Pump Relay located?
Like I said the Light comes on, then goes off, then comes back on for good.
brakes work fine, but I need it to come off for it to pass inspection.
Thanks, Jeff.
Old Oct 2, 2008 | 09:30 PM
UTI_TECH429's Avatar
UTI_TECH429
it is going to be under the hood in that fuse block but im not sure what relay it is but i think is says it one the cover of the fuse block.
Old Oct 2, 2008 | 09:31 PM
UTI_TECH429
and you could have problems within the brake system other than the relay.
Old Oct 4, 2008 | 02:50 PM
theblackmages
For all I know the brake system is completly fine, I did 520 KM with it and the brakes are perfect, mechnanic looked at them too and they're fine, He's now going throught the checking process for that light, we'll see what happens, he's almost finished and everything fine.
djbigskrilla
Sep 20, 2022 01:04 AM
movielover40
Aug 27, 2015 10:13 PM
labudski
Aug 24, 2015 07:23 AM
jjwinel78
Aug 17, 2015 03:34 PM
philster0306
Aug 10, 2015 11:33 AM
