posi unit
Old May 21, 2005 | 08:01 AM
white_snake's Avatar
white_snake
Default posi unit
ok if i buy this unit what else will i need to make my car posi?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
and is this thing any good. thanks
Old May 21, 2005 | 11:37 AM
99saleen351r's Avatar
99saleen351r
Default RE: posi unit
Dude your gonna have a pretty hard time with that seeing its not for your car thats for an 85 and down stang with an 7.5 rearend not a 8.8 which you have.I have a carrier for a 8.8 from a s351 for sale if your interested P.S. Your car comes with a limited slip rearend which is posi unless you wore it out doing one wheel peels
Old May 21, 2005 | 01:38 PM
Whoa's Avatar
Whoa
I'm pretty sure he has a V6 with a 7.5"....
Old May 21, 2005 | 04:54 PM
white_snake
ya i do have a 3.8 V6.
which is 7.5 i think. here is the diff tag.
so i know i will need to get other parts but will this fit my car and make it true posi? no one wheel peels.
[IMG]local://upfiles/13765/4CF9C9E9853F4CC2B7EBAEDA51C99D0E.jpg[/IMG]
Old May 21, 2005 | 05:10 PM
Djs94stang's Avatar
Djs94stang
I understand the confusion...your pic looks like a GT and I almost responded the same until I saw the quater mile time.....V6 is 7.5 inch ring gear...no posi.
Old May 21, 2005 | 06:18 PM
white_snake
ORIGINAL: Djs94stang
i know i dont have posi.. what i am still wondering is if the item in this link will work in my car.:
and if it will, is that all i need? and if i want to make it 3.73 gears all i have to do is buy the new gear and pinion, or what else will i need. thanks again
Old May 21, 2005 | 08:48 PM
P.S.I.cho's Avatar
P.S.I.cho
that piece should fit, not sure what else you would need tho
Old May 22, 2005 | 02:52 AM
99saleen351r
Sorry man i thought you just couldnt drive looks like a gt from the back,you should be all set then with that peice looks to be all you need
Old May 22, 2005 | 02:56 AM
99saleen351r
ORIGINAL: 2003bluestang
That auction has all you need other than gasket sealer,it has 373s which you want right?
Old May 22, 2005 | 03:41 AM
white_snake
ORIGINAL: 99saleen351r
i dont know if it has the 3.73 but i can always buy those later right?
