Cold Air Intake Install Question. Extra Hole?
Old Oct 9, 2008 | 07:52 PM
ShadowStang03's Avatar
ShadowStang03
Default Cold Air Intake Install Question. Extra Hole?
Hey Everybody,
I purchased the AmericanMuscle cold air Intake for my 03 GT. I actually haven't got around to putting it on yet , but when I was looking at it and checking it out I came up with a question. In the upper intake tube ( that goes from the throttle body to the MAF Sensor ) there are two tube inlets for the hoses, and another hole in the back with a rubber gromet in it. What is this hole for? The instructions were for a V6, and that hole was for the Air Temperature Sensor. I couldn't locate the same sensor on the GT. Do I need to get a rubber plug for this hole or what? Am i just not seeing the sensor? I am going to put it on after work tommorow, and I realize this is a novice install, but I dont want to be without something I need as this is my DD. Thanks
Old Oct 9, 2008 | 08:02 PM
ShadowStang03
Ok, so I looked at a whole bunch of install pictures for the GT and like half of them have the hole plugged with some metal thing ( which I don't have ), and the other half have the sensor. What's the deal here?
Old Oct 9, 2008 | 08:18 PM
Crobeson78's Avatar
Crobeson78
just grab a plug and plug it up. The hose is usually for nitrous.
i believe
Old Oct 9, 2008 | 09:13 PM
UTI_TECH429's Avatar
UTI_TECH429
the sensor that your missing is called and iac (intake air control) i believe you have one on the car. or you should at least
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Calizic
Aug 28, 2015 01:46 PM
panic
Aug 28, 2015 02:37 AM
12bigredstang
Aug 25, 2015 04:58 PM
