99 cobra rear abs sensor
Old Oct 15, 2008 | 11:45 AM
msalgolf's Avatar
msalgolf
Default 99 cobra rear abs sensor
I have a 99 cobra and my abs light is always on. I checked the front sensors and cleaned them. I can't locate the rear ones. Any help locating would be appreciated.
Old Oct 15, 2008 | 01:09 PM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
The rear should be near the rotors, to locate it, the wire harness runs along the floor pan to the sensor. If you need to, remove the rear lower seat and you should see the electrical connector. Just follow that to the speed sensor. It should be on the axle around the hub or rotor. Hope that helps. Also, make sure you use never-seize on it where it will reattach.
Old Oct 15, 2008 | 01:36 PM
msalgolf's Avatar
msalgolf
What is never-seize? An where can I get it?
Old Oct 15, 2008 | 01:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
How do you know its the sensor that's bad?
Old Oct 15, 2008 | 02:10 PM
msalgolf's Avatar
msalgolf
I figured I'd start by checking the sensors since the abs light won't go off. Why? Should I be checking something else? I figured I'd start my diagnostics at the source.
Nov 10, 2015 11:39 AM
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Sparks_88
Sep 8, 2015 01:06 PM
Sep 8, 2015 11:50 AM
