tire size help please
Old Oct 18, 2008 | 10:41 PM
bradplock's Avatar
bradplock
Default tire size help please
on my 95 GT, i just noticed that i have 255/45 on the front, and 275/40 on the rear. i understand that i have the wider tire in the rear, but why would my front tires have a thicker wall than the rear. now that i noticed it, it is very prominent and looks weird. is there a reason?
Old Oct 18, 2008 | 11:39 PM
LilRoush's Avatar
LilRoush
Someone put an off size tire on the fronts without regard to side wall height.
A better side wall match on the fronts would be a 245/45/17.
Old Oct 19, 2008 | 04:51 AM
Hlistr_07RR's Avatar
Hlistr_07RR
I always jizz first
^ Why not 275/40/17 on front?
Old Oct 19, 2008 | 08:50 AM
bradplock's Avatar
bradplock
lilroush, while 245/45 would be narrower, i'd still be in the same place having taller tires up front right?
hlister, now 275/40 up front sounds good
Old Oct 19, 2008 | 01:44 PM
OnyxCobra's Avatar
OnyxCobra
255/45-17 was the stock 94/95 Cobra size, I actually ran that size up front with 275/40s in the rear and the difference in size really wasn't noticeable. 275/40 up front will likely rub at full turn unless you have 03 Cobra A arms, but it also depends on the wheel size and offset.
Old Oct 19, 2008 | 02:54 PM
LilRoush's Avatar
LilRoush
245/45/17 was stock GT rubber.
45 percent side wall of a 245 width tire will be a lesser number than 45 percent side wall of a 255 width tire. People go 275/40 on the rear to get more bite and keep side wall profile similar. 40 percent of a 275 width tire gives you close to equal diameter on both wheels visually
A 245/45 tire will be about 25.4" tall
A 275/40 tire will be about 25.5" tall.
A 255/45 tire will be about 26.1" tall.
Exact size will vary by brand.
Old Oct 20, 2008 | 02:57 AM
Hlistr_07RR
I always jizz first
Mine doesn't rub at full turn, 275/40/17 all around....2001 Cobra
Old Oct 20, 2008 | 01:35 PM
bradplock's Avatar
bradplock
i do get some rub, on my front sway bars
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
M3hunter
Sep 5, 2015 03:42 PM
