oil change
Old May 24, 2005 | 08:44 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default oil change
my 1999 v6 stang is nearing 88k miles. got an oil change about 5k miles ago and i want to know what is best for the higher miles and mainly performance wise. 5w30.... is royal purple the best for performance? what do yall use? what about synthetic?
Old May 24, 2005 | 10:03 PM
white_snake's Avatar
white_snake
Default RE: oil change
i have always run synthetic, in all my vehicles. and read the owners manual, i think it says 5w30...but just use what ever weight it tells you too.
good luck
Old May 24, 2005 | 10:27 PM
Martinrulz's Avatar
Martinrulz
My '02 manual says 5w20.
Old May 24, 2005 | 10:29 PM
AtlanticBlue99
I ♥ Acer
mine says 5w30
edit: you have a gt, i have a v6
Old May 25, 2005 | 02:51 PM
Deannostang's Avatar
Deannostang
I run 10W-30 Royal Purple. Amsoil, Redline and Royal Purple are the premium synthetics out there. Mobile 1 is also pretty good.
http://www.redlineoil.com/products_m...3&synthFlash=1
http://www.royalpurple.com/techa/whyrpa.html
http://www.amsoil.com
Old May 25, 2005 | 03:05 PM
vfast's Avatar
vfast
I ♥ Acer
amsoil is really good
Old May 25, 2005 | 03:06 PM
luckythirteen13's Avatar
luckythirteen13
i run mobil 1 and like it but im going to try royal purple next time and see how that goes
Old May 25, 2005 | 03:12 PM
vfast's Avatar
vfast
I ♥ Acer
I have ran mobil 1 in my cars for over 20 years..not 1 oil failure
Old May 25, 2005 | 06:37 PM
Deannostang
I have also run Mobil 1 in many cars with excellent results. Took the head off a T-Bird Turbo to do a little work with the cam and valve springs and that engine looked spotless, just like new. Always ran Mobil 1 in that baby. If you are interested in a pretty good price on Royal Purple, Pep Boys now carries it at $5.99 a quart. Not bad since Mobil 1's new retail price is now $5.29 in the same store. Pep Boys does run specials on Mobil 1 alot at $3.99 a quart with a maximum of 12 quarts allowed at one time. Bottom line: ALL synthetics will do a much better overall job for you than conventional oils. Higher rpm's, more HP, longer drain intervals, zero sludging of any kind, better hot and cold weather running....pours like it's July at almost -50 degrees in the winter.
Old May 25, 2005 | 07:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, Mobil 1 is the bottom of the food chain regarding synthetic oils, but still better than dino oils. I use Redline oils and their filters.
