DISAPPEARING OIL
Old Oct 27, 2008 | 02:30 PM
valkrider's Avatar
valkrider
Default DISAPPEARING OIL
My son has a 2001 Mustang GT that is going through a quart of oil every 600-700 miles. There are no visable leaks or smoking. It has a cold air intake on it. The guy we bought it from had the cat's taken off. The car runs great. This is the second engine we've put in it. the first engine ran dry on oil and seized. We were not aware of any problems with that engine and within a month it ran dry. Does anyone have an idea as to what's up?
Old Oct 27, 2008 | 03:00 PM
uedlose's Avatar
uedlose
check and see if you can find any Ford service bulletins on oil consumption if you cant see it leaking it has to be burning it there is only so many places it can go. have you tried different oil or maybe a heavier weight.
Old Oct 27, 2008 | 03:31 PM
valkrider's Avatar
valkrider
went from 5w30 to 20w50. that did not seem to make a difference.
Old Oct 27, 2008 | 03:34 PM
GreyStang's Avatar
GreyStang
Stick your finger in the tailpipe. Are the inside walls kinda goopy?
Old Oct 27, 2008 | 07:54 PM
forcefeed's Avatar
forcefeed
check the pcv system and make sure its not sucking it in through the valve. Have you pulled the plugs and had a look to see if there are any signs of oil consumption?
Old Oct 27, 2008 | 10:53 PM
Jfsram's Avatar
Jfsram
I don't know if your 4.6 is plagued with the same problems as the first 205 hp versions.
Had a 95 T bird with major oil consumption. It was valve seals, which is a common problem among those cars. First hint is after extended idling, like at a drive through line up or bumper to bumper traffic. It's smoke city out the tailpipes when you accelerate after.
Old Oct 31, 2008 | 12:15 AM
ym42's Avatar
ym42
First of all, oil is cheap. I had a Toyota with the same problem 1 qrt/600 miles and it has been like that for the last 250 000 miles. One of the oils I liked was Exxon 10w-40 that seems to stay longer inside. Do you see any smoke from the tailpipe? Did you check if the engine is all dry and clean? Go under and see, may be some seals? In any case its not a major problem, but the reason cats were taken off might be that they were fouled by the oil in the exhaust may be? But its just my guess I am no mechanic...
Old Nov 3, 2008 | 11:09 AM
zippo2341's Avatar
zippo2341
check your plugs, and tail pipe as previouslly mentioned. look for leaks at rear main seal. valve cover gaskets, i dont know if the 4.6 have these or not buck check the cam seals. check your pcv valve out to. other then that stick some cardboard underneath and look for a drip, then where it came from.
Old Nov 3, 2008 | 11:12 AM
zippo2341's Avatar
zippo2341
i just checked they do have cam seals. i had one go bad on an eclipse gst, and it was leaking like crazy but couldn't find out where untill i did a real good inspection, with the valve cover off
Old Nov 3, 2008 | 12:48 PM
forcefeed's Avatar
forcefeed
not sure what you checked but the 4.6 does not have cam seals!!!
