starting problem
Old May 29, 2005 | 01:56 AM
jasper002002's Avatar
jasper002002
Default starting problem
1987 mustang gt ,5 speed..stock motor
just picked it up,changed ground to chassis(was weak).also changed starter and solenoid,battery,and terminal connectors.after each change it started right up.after each first drive and shut down,it would not start(with the sound of a dead battery.i do have full power also even when it wont start.runs fine till you shut her down after each repair.then same thing.when its warm,it wont start at all.any suggestions.possibly another bad ground,or cables themselves bad????when it runs,it is smooth and idle is perfect.
Old May 30, 2005 | 01:16 AM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: starting problem
bad starter...?[&:]
Old May 30, 2005 | 01:46 AM
dc_mann8's Avatar
dc_mann8
solenoid id say? dont they not start when its warm? or is it when cold.. dunno..
Old May 30, 2005 | 09:54 AM
jasper002002
thanks fellas,tracked it down to bout every ground under the hood being bad.new battery helped too.thanks again.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
