Fuel Cell - Never had one ...
Old Jan 3, 2009 | 01:28 PM
Sparky73's Avatar
Sparky73
Default Fuel Cell - Never had one ...
I just purchased a 1980 Mustang in which the fuel tank was replaced with a fuel cell in the hatch area. Is there any type of gauge I can get that will work with a fuel cell?
Possibly something like this?
http://www.dunebuggy.com/shop/index....urnTo=FEATURED
This is a 12 or 13 gallon cell with foam. None of my gauges currently work, so I'd have to find either a sending unit with a gauge, or a sending unit and purchase a separate gauge that would be compatible.
Old Jan 3, 2009 | 05:38 PM
Gary H's Avatar
Gary H
check places like summit and jegs, they sell the senders etc for fuel cells. You may need a different cell that is set up for a sender.
http://www.jegs.com/p/JAZ/758812/10002/-1
Then you can use whatever gauge you want.
Old Jan 3, 2009 | 11:49 PM
Sparky73's Avatar
Sparky73
If I got the info on the fuel cell (brand, model #, ect), would I be able to figure out whether it WILL take a sending unit?
Old Jan 5, 2009 | 11:02 AM
Gary H's Avatar
Gary H
Should be able to, or find one of similar dimensions.
Old Jan 8, 2009 | 09:42 PM
toofst4u666's Avatar
toofst4u666
does the cell have a built in sending unit? if it does then 90 percent of the time they run a 0-90ohm unit which gauges are a dime a dozen i personally used an autometer phantom fuel gauge which was 40 bucks on my rci 15 gallon cell and it works dead on.
Old Feb 15, 2009 | 08:33 PM
Sparky73's Avatar
Sparky73
Just an update on this. It's getting closer and closer to Spring and I still got a lot to do. I found the original receipt for the fuel cell, so I now have a part # to work off of. Can anyone tell me if a fuel sending unit is avail. for it?
12- Gallon Capacity
17-1/2" L x 16" W x 10" H
Part # 547-250-012-01
http://www.jegs.com/i/JAZ/547/250-012-01/10002/-1
Would this sending unit work?
http://www.jegs.com/i/JAZ/547/378-070-03/10002/-1
CS2007
Jun 25, 2019 09:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
mrappe
Sep 26, 2015 10:16 AM
