got a question
Old Jan 10, 2009 | 05:11 PM
quiet_storm's Avatar
quiet_storm
Exclamation got a question
ok so ive noticed that there is a squeaking like sound coming from the left side of the car when i drive. i only used to hear it whenever i went on the interstate or goin over 70 and if i take a turn a little bit too quick. now im hearing it a little more often. also when i take off, my e-brake light flashes on then turns off.
do any of these sound serious?
Old Jan 10, 2009 | 05:33 PM
96GT34's Avatar
96GT34
does it only do it when ur turning and when u go over bumps?
Old Jan 10, 2009 | 05:41 PM
quiet_storm
that and it'll go off randomly sometimes if im just driving. like i said its like a squeaking-chirping type of sound.
Old Jan 10, 2009 | 07:44 PM
FORD TOUGH's Avatar
FORD TOUGH
You should probably take it to a shop and have the check it out. It could be a number of thing causing the noise.
Old Jan 10, 2009 | 08:18 PM
96GT34's Avatar
96GT34
more than likely sounds like a ball joint gone bad, and its defiantly coming from the front right?
Old Jan 10, 2009 | 09:02 PM
quiet_storm
yeah its def comin the front left side
Old Jan 10, 2009 | 09:13 PM
huck1974's Avatar
huck1974
Does the light go off every time?
What kind of squeaking noise?
When your sitting in the drivers seat, everything sounds like it is coming from the left side.
Why don't you pull your rear wheels off and take a look see. Just my opinion.
Old Jan 10, 2009 | 10:46 PM
quiet_storm
well the light only goes off when i take of a little quick...so i think the problem with that is just the actual take off but im not sure.
its like a squeaking, chirping like noise im really not sure how to describe it better then that. and yes its coming from the left side. i havnt had a good amount of time to actually looker under the hood to see if maybe somethings just loose but hopefully i can take a look tomorow.
Old Jan 11, 2009 | 10:57 AM
96GT34's Avatar
96GT34
go to the front left or w/e side its on and push up and down on that side see if it makes that noise
Old Jan 11, 2009 | 01:03 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Check the condition of your brakes pads while you're at it
