Will I pass emission testing??????????
Old Jan 23, 2009 | 01:56 PM
saleen0101's Avatar
saleen0101
Default Will I pass emission testing??????????
I have the stock exhaust system with 2 precats and 2 main cats. The car had the 2 main cats removed and their has never been a check engine light because of this. The car is a 2001 and I know they dont do the sniffer tests on 2001+. So my question is, will I pass emissions testing with just 2 pre cats? car runs fine. I also, had a iac restrictor plate installed, dont know if that will affect anything or not. And just installed a new battery, will the car be ready for testing right away or should I drive it awhile and how long ?? Thanks for any input guys.
Old Jan 23, 2009 | 02:46 PM
945LSTANG's Avatar
945LSTANG
as long as there is no visual and you dont have a CEL you should be good to go.
Old Jan 23, 2009 | 03:10 PM
saleen0101's Avatar
saleen0101
Cool thanks for your input. No, there is no visual. What about the new battery that I had put in?? Wont that clear all the computer's memory? Should I drive it for a day or two to be sure?
Old Jan 23, 2009 | 04:31 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
You should take it on a highway trip or 2 for a few days.. Whenever you replace the battery it clears the PCM, and you will throw a non-readiness code and they will fail you for it. Give it a couple good long drive cycles first, then take it thru
Old Jan 23, 2009 | 08:31 PM
LilRoush's Avatar
LilRoush
Without the main cats, you won't pass visual inspection or a sniffer.
Old Jan 23, 2009 | 09:41 PM
saleen0101's Avatar
saleen0101
lil roush, my car is 2001+ so there is no sniffer test, you are wrong man. If you didnt read my original post, i stated there is also no visual.
Thanks for your help whitefoxgt. I will go ahead and do what you said, thanks again.
Old Jan 23, 2009 | 10:03 PM
LilRoush's Avatar
LilRoush
If there is no visual and no sniffer... what kind of emissions testing are they doing?
Old Jan 23, 2009 | 10:46 PM
saleen0101's Avatar
saleen0101
2001+ use the obdII port and they just plug in to read the computer. The computer will tell their device if everything reads out ok. I know if you have a check engine light, they will fail you on the spot.
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
mrappe
Sep 26, 2015 10:16 AM
