69 Restoration HELP!
Old Nov 4, 2003 | 11:57 PM
69StangCpe's Avatar
69StangCpe
Default 69 Restoration HELP!
I've got a 69 coupe that i am in the process of rebuilding. The most current problem i am having is i cannot get the front wheels straight. The top of the tires are leaning in about 2-3 inches past center. I have replaced the coil springs three times and also ordered the springs from 3 different contacts. The reason i suspect the coil springs is because the upper control arms arm within millimeters of hitting the frame just below the upper arm. I can placea jack under the front hub assembly thinking it would just raise the arm - the whole car was rising with the jack- thus making me think that the springs are too heavy? Any suggestions? What is typical clearance of the control arm to the frame? I have also replaced, with new parts, the entire front end suspension and steering parts. I have tried adjusting the the lower control arm thinking it would pull the bottom of the tire in, and it just enough enough...</P>
</P>
Please Help!!!</P>
Old Nov 5, 2003 | 01:28 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Is this with the tires in mid-air or on the ground? On the ground, I'd be pretty concerned, in the air I wouldn't pass judgement untill I put a load on them.
Old Nov 5, 2003 | 09:03 PM
69StangCpe's Avatar
69StangCpe
Its with the tires on the ground and in the air -it doesnt matter, they dont move when releasing the weight of the car.
