Handling question
Old Mar 13, 2009 | 09:39 PM
S.V.T's Avatar
S.V.T
Default Handling question
How well can I expect my 1998 Cobra to handle with these mods? 76,000 Miles.
Centerforce Clutch
31 Spline Limited Slip
31 Spline Alloy Usa Forged Axels
3.55 Gears
Steeda Tri-ax Shifter
Aftermarket Upper and Lower Control Arms
Eibach Springs
Tokico Adjustable Illumina Series Shocks
Aluminum Driveshaft
Subframe Connectors
Slotted Rotors Front and Rear
Old Mar 13, 2009 | 10:12 PM
Fobra's Avatar
Fobra
Banned
add front and rear strut braces, performance bushings and good tires, and stainless brake lines w/ performance pads and forget the drive shaft - your just pissing money away. Car should be a good corner carver, there is more you could do, but not without dropping major $. weight reduction and I think they make a quick ratio steering box upgrade as well.
Old Mar 13, 2009 | 10:17 PM
S.V.T's Avatar
S.V.T
I'm getting the car with all those already in them.
Old Mar 14, 2009 | 09:17 AM
GreyStang's Avatar
GreyStang
Most of those mods do nothing to improve handling..
"Aftermarket control arms", which ones?
Toss in some bigger anti-sway bars & it'll probably handle pretty good though. What kind of wheels/tires does it have?
Old Mar 14, 2009 | 11:09 AM
USMC1775's Avatar
USMC1775
Get a panhard bar and bigger swaybars. And Steeda X2 balljoints up front to help the geometry
2015Ecoboost
Sep 17, 2015 01:48 PM
Dragonus18
Sep 9, 2015 01:21 AM
mungodrums
Suspension
Sep 7, 2015 07:28 PM
