car wont start?
Old Mar 14, 2009 | 03:56 PM
longer38's Avatar
longer38
Default car wont start?
hey guys my buddy has a 2000 gt and his car wont start. just keeps turning over but will never fire and his anti-theft light continues to blink repeatedly. the dealership keeps saythin that they need to re-flash his chip in his key and want to charge a arm and leg for it. now last year i was workin at a detail shop and this happen on a F-150 we had in. i called the 800 number in the back of the owners manual and they talked me through a sequence of putting the key in the ignition, turning it to the on position then hitting the lock and unlock on the keyless entry pad. does anyone know how to do this? tried callin them back but now they have no idea what i'm talkin about. anyway sorry for the long rant but any help would be greatly appriciated, thanks
Old Mar 14, 2009 | 06:52 PM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
The sequence your talking about is programming a key FOB(for unlock/lock/trunk) purposes. Programming the actual key to cooperate with the PATS system is a whole different story; which I'm fairly sure can only be done at a dealership or shop.
Car turns over, fires, but won't start. Doe's it have fuel pressure?
Old Mar 14, 2009 | 09:57 PM
sprinklerdr's Avatar
sprinklerdr
With the light blinking fast, it's in the key or the PATS sensor on the ignition switch. Sorry man, but it's a trip to the dealership for ya. Does he have another key?
One more question: Is the car chipped by (insert speed chip company here)? When I was testing Diablo chips in early 2001 for the Focus, the chip would make the PATS system go crazy if the chip had wiggled the least bit loose.
Old Mar 15, 2009 | 12:14 AM
mustangcat's Avatar
mustangcat
The "THEFT" light on New Edges will blink fast regardless. The only time it doesn't blink is when the car is actually running.
Old Mar 15, 2009 | 09:37 AM
sprinklerdr
Thanks cat...I'm out of the loop on the newest theft deterrent stuff.
Old Mar 15, 2009 | 10:49 AM
longer38's Avatar
longer38
yea he has fuel pressure and yes the car has SCT switchchip. but unfortunatley it sounds like we'll be towin it to the dealership. thanks for the input so far.
Old Mar 15, 2009 | 04:01 PM
mustangcat's Avatar
mustangcat
Anytime man!
And you've tried de-tuning the car from the Chip?
And how did you check for fuel pressure?(Fuel pumps on these cars are pretty sensitive)
Old Mar 16, 2009 | 07:54 AM
longer38's Avatar
longer38
Originally Posted by mustangcat
Anytime man!
i'm not sure if he has tried that or not, if not we'll give it a try. and the car has a aftermarket fuel pump on it. forget the exact model but he insisted it had pressure i wasnt with him when he checked so just going off his word.
Old Mar 16, 2009 | 03:25 PM
mustangcat's Avatar
mustangcat
Checking the fuel pump/relays/inertia switch is something to look at.
An easy way to do this is just switch the Key to "ON", and listen for the "Vrrrrrrrrrr" the fuel pump makes when it's engaging. You could have someone stand near the fuel door to make it easier.
The inertia switch will activate if he's bumped into anything, mines activated after a bad pothole. It's located in the trunk, left side, near the tail light, behind the carpeting theres a small black box with a red button on top. If the button is "UP" press it "DOWN." This stops any chance of a fire in case theres an accident.
djbigskrilla
Sep 20, 2022 01:04 AM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
89blueslug
Aug 10, 2015 07:20 AM
