24 lb injectors
Old Apr 9, 2009 | 09:42 PM
90dropstang's Avatar
90dropstang
Default 24 lb injectors
i put 24 lb. injectors in my car match with the mass air meter, when the car gets hot it idle's irradically. So i put the 19lb. meter in with the 24 lb injecters the car runs fine like this! Do i have to reprogram the computer in the car to run this or does any one know of any other option?
Old Apr 10, 2009 | 04:49 AM
Obsequious1's Avatar
Obsequious1
If you put larger injectors in your car, then you need to recal your maf to the new injectors. Yes, reflash your computer.
What is your reason for the 24lb injectors.
Welcome to MF's
Old Apr 10, 2009 | 07:38 AM
90dropstang
i put the 24s in for a upgrade. i got trick flow upper and lower, 75mm throtle body, and a crane power max cam, 3" ex, with short headers.
Old Apr 10, 2009 | 07:40 AM
90dropstang
how do you refresh your computer, this is my first efi
Old Apr 10, 2009 | 05:04 PM
Timspony's Avatar
Timspony
SVT Section Moderator
You don't reflash a Fox computer....make sure the MAF is cal. for 24# injectors! ...what is your set-up that you need to install 24 # injectors???
Old Apr 11, 2009 | 12:27 PM
90dropstang
i got a 75 shot of nitrous
Old Apr 11, 2009 | 03:46 PM
Timspony's Avatar
Timspony
That's the only mod ^^^??? ....with the nitrous you don't need as much injector as say a SC or turbo...
Old Apr 11, 2009 | 10:06 PM
90dropstang
should i switch back to the 19lbs?
Old Apr 12, 2009 | 11:44 AM
P.S.I.cho's Avatar
P.S.I.cho
if its wet you definatley dont need the 24's but a bigger injector is safer but u will need a tune
Old Apr 12, 2009 | 11:01 PM
90dropstang
thanks for the help
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
