EFI and Camshaft
Old Apr 21, 2009 | 02:23 AM
clarkp81's Avatar
clarkp81
Red face EFI and Camshaft
The camshaft that I have in my 289 says that it is built for the street but I don't know if it will work well with a 5.0 EFI system. The specks are:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-4,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 228
Advertised Intake Duration: 276
Advertised Exhaust Duration: 286
Advertised Duration: 276 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.471 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.471 in. Valve Lift with Factory Rocker Arm Ratio: 0.471 int./0.471 exh. lift Lobe Separation (degrees): 114
Does anyone know if I will need to replace my cam, or if this will work fine with a late model EFI setup?
Old Apr 21, 2009 | 10:28 AM
67mustang302's Avatar
67mustang302
It's not a huge cam, and with a 114 LSA it should probably work fine. Still though, factory computers can be persnickity, but either way it'd need to be tuned for best performance. There's a lot of options out there to tune them.
NYstang
Sep 30, 2015 09:56 PM
Ipaman
Sep 22, 2015 07:01 AM
uberstang1
Sep 20, 2015 06:42 PM
jaiidutch
Sep 14, 2015 10:29 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
