Serious Vibrations in Car
Old May 19, 2009 | 12:58 AM
UFG's Avatar
UFG
Exclamation Serious Vibrations in Car
Hi guys, I tried searching for this in the forum but to no avail so I'm sorry if this has been posted before.
Here's what I have:
2003 Mustang Convertible V6
74k miles
This weekend, I was driving from San Diego to Los Angeles on the freeway when I noticed my car was shaking more than usual. However, on the first half of the trip (San Diego to Irvine), the car was fine, but sometime during the second half of the trip (Irvine to Los Angeles), the car began developing very strong vibrations on the freeway. It was so bad that I could barely look at my rearview mirror without feeling dizzy.
I made it back to Los Angeles and checked my car, but there appeared to be no exterior signs for the occurance.
Here are some other important things to note:
- On flat surfaces, the car will vibrate as though it were on a bumpy road.
- At low speeds, the car will have a rhythmic bump, changing depending on speed. This leads me to believe that there is something in one of the tires that is causing the problem, but I have read in other places that it may be the driveshaft?
- All tires are properly inflated and the wear pattern looks normal.
- Ever since I got it (69k miles), the car has always pulled slightly to the left.
- I did not run over anything large (or large enough to notice).
- It seemed that the entire problem started within quite a short timespan (I'd estimate within 5-20 minutes), but I did not notice it immediately since the freeways around LA are quite bumpy to begin with.
If anyone has any recommendations or needs more information to diagnose the possible problem, please let me know. The shaking is VERY scary at freeway speeds!
Thanks!
Old May 19, 2009 | 02:01 AM
mudvayne1's Avatar
mudvayne1
Check your ball joints, tie rods and you can also check your u-joints on your driveshaft while your at it.
Old May 19, 2009 | 05:35 PM
Monkeyleg's Avatar
Monkeyleg
Very possible that you hit a bump that broke one of the belts in the front left tire. My wife did that with her car in December, and the symptoms were exactly what you describe.
Old May 20, 2009 | 04:18 AM
UFG's Avatar
UFG
How much do you estimate it is to fix this? My budget is tight
Old May 20, 2009 | 04:27 AM
Sxynerd's Avatar
Sxynerd
When's the last time you locked up your tires? Could have a flat spot.
Old May 20, 2009 | 10:12 PM
Monkeyleg's Avatar
Monkeyleg
How much do you estimate it is to fix this? My budget is tight.
The price is a new (or newer used) set of tires for the front. You shouldn't mix different tread designs or number of miles on tires, at least in the front.
squishbang
Suspension
Nov 2, 2015 03:42 PM
Luclin999
Sep 7, 2015 11:33 PM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
