HID install help!!!
Old May 19, 2009 | 09:00 PM
natistang's Avatar
natistang
Default HID install help!!!
I bought the dual beam 9007 600K HID kit from VVME.com and also the 880 6000K fog light kit. I hooked everything up, checked it twice, and turned the lights on. My drivers side headlight and pass. side fog light will not turn on. It looks like there is no power going to it what so ever. I checked the wires again and everything is hooked up correctly. Has anyone had this problem before and if so how do is fix it. Also, i checked the bulbs and they are not blown. Thanks!
Old May 19, 2009 | 09:04 PM
antiv6's Avatar
antiv6
try switching the ballasts around and see if the other side lights up. if nothing changes id run it through a relay instead of your stock wiring harness so there getting power through just the battery. relays are only like 15 bucks each. The initial power up of hids take a lot of power
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
