Gears install
When u buy gears online, do u need any thing else to give the mechanic to install them, cuz 189.00 dollars for gears is mighty cheap. I would hate to order them, and then find out i have to also order a install kit for them or somethin like that. do u guys kno how much of a performance differnce they will make. i have 1994 gt aode conv, i think i got 3.07 or 3.06's stock. thanx alot guys
Yes, there are a couple of suggested install kits that you should have as well. One is for a strict gear change and the other is if you are going to replace the bearings at the same time. If you are around 35,000 miles or less, a bearing change is not really necessary. They also sell a kit with a limit slip rebuild if you want to go the whole nine yards. Just check any website that sells gears and you will see the companion kits listed with them.
Just one example of a place to start: http://mustangsunlimited.com/itemdy0...=&CatKey=74-01
musnicki
Sep 23, 2015 07:11 AM
Sep 3, 2015 07:14 PM
