HELP HELP
Old May 28, 2009 | 07:28 PM
labtec101's Avatar
labtec101
Default HELP HELP
ok so i got a 1996 mustang and the key was replaced now when i put the new one in the theft lock comes on is there a way to disengage the theft lock i.e. a fuse cutting wires etc or is this a more complicated fix like going to the dealership and getting it replaced.
Old May 28, 2009 | 08:58 PM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
So when you put the key in the ignition the theft light comes on, and the car won't start?
You'll be needing a trip to the dealership in order to reprogram your PATS(Passive Anti Theft System) on your Key/Car.
Old May 29, 2009 | 10:05 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Yep, the PATS system doesn't recognize the new key, it needs to be reprogrammed by Ford. If you want any additional spares or remotes, now would be the time to do that all at once. The PATS system has a chip in the key that communicates with your vehicle and allows it to start, if that chip isn't present or it doesn't recognize the chip, your car will not start. It prevents someone from either getting a blank cut and stealing your car or the ole screwdriver in the ignition.
Old May 30, 2009 | 08:50 AM
labtec101's Avatar
labtec101
and how much is that going to cost
