Motor from truck to car?
Old Jul 10, 2009 | 11:35 AM
syxxturbo's Avatar
syxxturbo
Default Motor from truck to car?
i have access to a 92 for f 150 with a 5.0 in it. was wondering if i could take it out and throw it in my 87 gt stang, the only intell i have found is that it uses a different firing order in the truck but that i can use mustang firing order once installed. this engine would be my builder motor. would like to build a cammed out NA . second question i have is would i be able to use the stock wiring harness from the truck to convert my stang to a MAF setup or can i make good numbers with out it? any help i could get would be greatly app.
thanks guyz
Old Jul 10, 2009 | 11:41 AM
ryan1994mustang's Avatar
ryan1994mustang
im not a genius in this subject, but im pretty sure you cant change the firing order in an engine without changing the whole crankshaft. the firing order has to do when each piston reaches TDC. its not going to do any good if the spark plug ignites the fuel when the piston is at the bottom of its stroke. you can probably use the trucks distributor and just power it with your mustang coil, but you cant change the firing order.
Old Jul 11, 2009 | 02:11 AM
Jfsram's Avatar
Jfsram
Good answer in theory but in actual Ford applications. It's the camshaft that determines the firing order.
Old Jul 13, 2009 | 06:22 PM
syxxturbo's Avatar
syxxturbo
i had heard that the cam was the only difference as far as internals go. i think the truck 5.0 made less power but more tq than the mustang 5.0. im just interested in it for the block. gonna be the motor on the stand for a while .
djbigskrilla
Sep 20, 2022 01:04 AM
01blackgtconv
Aug 14, 2015 04:50 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
01blackgtconv
Aug 10, 2015 01:25 PM
