burnouts
Old Jul 4, 2005 | 07:31 PM
91stang's Avatar
91stang
Default burnouts
i know this sounds stupid but i'm losing money casue of it. when i do burnouts only my left tire spins and it's eating it up. i just had to get it replaced but my right one is perfectly new. i've heard of something to make em both spin but i can't remember what it is.
Old Jul 4, 2005 | 07:33 PM
cammedlx's Avatar
cammedlx
Default RE: burnouts
Ford's put a trak lok in your 8.8 from the factory which they use clutch style disc's to lock both wheels together in a straight line and let them slip alittle in the corners,so you probaly need to rebuild the trak lok with new clutch's in order to get rid of your one wheel peel blues.
Old Jul 4, 2005 | 07:39 PM
91stang's Avatar
91stang
so what all would i need to get for this to stop? i heard there was a quasi somehting i think it was called to get both tires to spin
Old Jul 4, 2005 | 08:25 PM
Fishhawk's Avatar
Fishhawk
Quasi something? You need your Traction Loc rebuilt, or just get a new differential.
Old Jul 4, 2005 | 09:24 PM
stanglx2002's Avatar
stanglx2002
you need a $50 trac lock rebuild kit
Old Jul 4, 2005 | 10:00 PM
ZachW04Stang's Avatar
ZachW04Stang
ORIGINAL: 91stang
Quasi? I think you thinking of posi. You have it but its worn out, you need to rebuild your differential and you will have no problem breaking both wheels loose.
Old Jul 5, 2005 | 12:02 AM
91stang's Avatar
91stang
haha yea... that's what i meant. i feel stupid now [&o] you sure i have it? i know this is another newb question but what is a posi exactly?
Old Jul 5, 2005 | 12:10 AM
mkspeed26's Avatar
mkspeed26
a posi is just a different way of making it so the vehicle can turn easier by allowing the wheels to trun at different speeds. u can research it if i want to see how it works. all u will need for the rebuild is the kit, some rear end oil, friction modifier, and some gasket maker
Old Jul 5, 2005 | 12:27 AM
91stang's Avatar
91stang
ok... i undersatnd what posi is. but how is that keeping one tire still while burningout?
Old Jul 5, 2005 | 12:42 AM
mkspeed26's Avatar
mkspeed26
well, it is the "limited slip" part of it. it is also used as a safety feature. if one wheel breaks loose (ice, etc) it puts all of the rpms to the slipping wheel so the non-slipping wheel doesnt drive the car towards the slipping wheel. so when u break a wheel loose, it stops the other one.
