Engine Studdering but not light??
Old Aug 13, 2009 | 04:24 PM
Kween's Avatar
Kween
Question Engine Studdering but not light??
Ok long story short. I had this problem once and changed the spark plugs and hasnt happened since. I was on my way back from vegas driving 2 hours 115 degree weather and a/c running. All of a sudden i wasn't going anywhere in traffic. My foot was pressed on the gas as far as it would go without flinesoning it and i was misfiring (or something like that). Could barley make it off the freeway....It never threw a check engine light. Had it towed from Yermo to barstow (like 10 miles max) had to switch tow trucks and the first guy said i had tranny fluid all over his bed. So i towed it alllllll the way home and took it to the shop the next day. They said no leak....... So i got under there myself low and behold its a speeping (Verrrrryyyyyyy slow) leak from the tranny pan gasket, nothing to freak out about. The misfire was never found because it didnt have the check engine light and has not done it since. So the question is what would cause the car to not want to go and if i should rfix the leak (the shop said its nothing to worry about)? It's a 04 base model with no mods @ 84K.
Old Aug 14, 2009 | 08:49 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Could be a tranny issue. If you had the pedal pressed and the engine was revving but not moving, I would say it is your tranny. Need to check the level on the fluid, when fluid gets low you won't go anywhere. Did it happen all at once or did you notice that it was just getting progressively worse as time went on?
Old Aug 14, 2009 | 04:54 PM
Kween's Avatar
Kween
It only did it a few times and progressivly got worse (to the point where i felt bad and didnt want to damage anything else lol)...The fluid was completely full. Some say Vapor Lock, Full Pump/Filter (had that checked and it was A ok), Bad gas (i used chevron like always) and even after i had the car back in orange county it drove fine with the same gas.... It is leaking where the tranny meets something else. Im thinkin if there is an O ring (OH NO not the o ring haha) that's what needs to be replaced. The tranny isn't shifting hard at all. I swear im doomed with not being able to find out what is wrong....
Old Sep 2, 2009 | 04:13 PM
Kween's Avatar
Kween
OK did it again this weekend, but worse to where you can see and hear the engine struggeling to turn over.... Had it towed from San Diego. Check engine light was FLASHING not on so i looked in the manual and it said if it flashes than its misfiring.....Turned out to be the spark plug wires. Had them replaced and its been running like a champ since.
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
Nov 5, 2015 04:18 PM
J.casone400
Aug 28, 2015 09:33 PM
inyadreems
Aug 21, 2015 09:10 AM
drumhedd2005
Aug 13, 2015 09:59 AM
