Poor Acceleration
Old Aug 19, 2009 | 05:49 PM
topnotchpgt's Avatar
topnotchpgt
Exclamation Poor Acceleration
I have a 2002 Mustang GT, automatic.
i just bought the car but it has poor acceleration.
while your accelerating it boogs out but when i catch speed it very smooth.
I have changed the sparkplugs to (motorcraft platium)
air filter
fuel filter
the car does not have a check engine light on..again it does not have it on.
also when the car is on idle is a little rough.
any ideas?
i dont know what else to do.
please help!
Old Aug 19, 2009 | 07:12 PM
SkillzDatKillz's Avatar
SkillzDatKillz
Mista High School Playa
idk...it probably has something to do with it being a mustang
Old Aug 19, 2009 | 07:27 PM
Stone629's Avatar
Stone629
That bogging is just your torque converter locking up, its normal. The rough idle is the nature of it too. Honestly though, you bought the slower of the 4.6 New Edge Mustangs. The automatic GT falls short of the manual in acceleration. Start modding it and you should be happier with it. If you really want to make it move, get some 4.10 gears.
GreyStang's Avatar
GreyStang
Great help, SkittlesDatKill..
When you punch it does a lot of dark 'smoke' come out of the exhaust? The engine could be all carboned up from the previous owner lugging it too much.
You should probably get the injectors cleaned that'll help a LOT. Not just a jug of stuff that goes into the gas tank but a real injector clean at a garage,. usually cost around $50-70
Old Aug 19, 2009 | 07:30 PM
Choppa's Avatar
Choppa
maybe the MAF?
Old Aug 19, 2009 | 09:41 PM
PistolPete79's Avatar
PistolPete79
get a tuner so you can set the shift points and firmness and turn off the torque modulator! that helps a lot!
Old Aug 19, 2009 | 10:47 PM
DreamerGT's Avatar
DreamerGT
how many miles are on it?
Old Aug 20, 2009 | 08:12 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Skillz, keep that crap out of the tech sections. We let you slide in S&S, but keep that crap up in here and you are gone.
Old Aug 20, 2009 | 11:16 AM
topnotchpgt
the car has 110k
what is a torque modulator?
one time smoke came out.
how do i clean the slug?
what else can it be?
Old Aug 20, 2009 | 11:39 AM
Jfsram's Avatar
Jfsram
Before you do any "tuning" or "gear swapping" you need to put a clear definition to poor acceleration.
If it's running so poorly that it shakes at idle and accelerates like a 17 second minivan. Do not apply any of those suggestions.
I'd start with a full tune up, especially if you just bought the car. If it's still no good. Have the codes read.
