steering turns on braking
Old Aug 19, 2009 | 05:51 PM
ron2k9's Avatar
ron2k9
Default steering turns on braking
Hi,
I recently replaced all 4 tires on my 2001 Mustang (base) with fuzion HRI. I just noticed that my steering wheel turns slightly to the left or right when I brake moderately hard/hard.
Is this supposed to happen with new tires or is there something wrong with my car?
Thanks for your help..
Old Aug 19, 2009 | 05:54 PM
89gtwith3.55s's Avatar
89gtwith3.55s
could be alignment... drive on a flat road an let go of the wheel see if it drifts
Old Aug 19, 2009 | 06:23 PM
ron2k9's Avatar
ron2k9
Hi,,
thanks for replying. I got alignment before I replaced my tires. Additionaly I recently drove
on a highway at 70+ and did not notice any drifting..
Old Aug 19, 2009 | 09:28 PM
67mustang302's Avatar
67mustang302
Sounds like mild bump steer. Is the front suspension worn out?
Old Aug 20, 2009 | 11:47 AM
Jfsram's Avatar
Jfsram
Moderate braking will not induce bumpsteer.
Is this a stock suspension with stock size tires?
The slight turning? Do you mean brake and it pulls slightly to left OR right on a flat road wtih not depressions in the pavement from heavy trucks?
Old Aug 20, 2009 | 01:03 PM
67mustang302
Moderate braking can induce bump steer if the suspension is worn, the car will generate too much dive and the steering linkage will swing past a level position and toe the front wheels out. That's why I asked if the suspension was worn.
Old Aug 20, 2009 | 09:16 PM
ron2k9's Avatar
ron2k9
I replaced the left tie rod (outer) for my car a month ago.. During which I got the suspension checked and I was told that its ok...
I did a little more testing today and found out that the slight turn of the wheel happens during the final moments before the car stops...
i.e slowing down from 40 mph to 10 is ok (straight braking), the wheel turn while bringing the car down from 10 to 0...
it also happens when I apply the brakes when the car is on idle acceleration.. (in Drive ofcourse)
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
