65 v8 cam question...need help
Old Aug 28, 2009 | 11:38 PM
phish's Avatar
phish
Default 65 v8 cam question...need help
i have a 65 coupe 289 with a 3 speed. i recently added tri-y headers and flowmaster 40 full exhaust. it is also is a 4 barrell if that means anything..... my question is i am gonna add a cam, what is the best cam available regardless of price. i like a nice loud choppy sound, but i have heard if u go too big it can effect performance. this prolly the last engine mod i will add so keep that in mind. honestly have no idea about engines, so whatever u guys suggest i am gonna get....... someone suggested a big bertha cam, sound familiar??
thank you so much in advance for all responses
Old Aug 29, 2009 | 02:25 PM
capri man's Avatar
capri man
i would suggest a cam with nominal lift (under 500) with a lot of overlap. that is why the stockers in drag racing have such a loud poppy sound to them.
Old Aug 29, 2009 | 10:15 PM
67mustang302's Avatar
67mustang302
Typically an off the shelf cam with a choppy sounding idle, won't make good power in a mostly stock engine, the car needs to be built up to use it right, and often the cam that makes the best sound(subjective) doesn't make the best performance. Call a cam grinder like FTI or Camshaft Innovations and have them grind you a hydraulic roller cam. I wouldn't even try screwing with flat tappets these days, modern oils suck ***** with flat tappets and they're hard to break in. A roller will run better anyway.
Old Aug 30, 2009 | 02:56 PM
falcon65's Avatar
falcon65
The hydraulic roller cam option is a good one, however it will require you to drill holes in your lifter valley to retain the roller lifters from turning in their bores. If this is something you are comfortable with taking on, it is hard for a flat tappet cam to rival the gains of a roller. Sure fire way to find the cam for your combo is to call a cam help line. Make sure you are prepped with all the info they will require to get it right for you. Tire height, gear ratio, car weight, and desired rpm are just a few...good luck
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
