Carb suggestions?
Old Sep 20, 2009 | 10:35 AM
68stanger's Avatar
68stanger
Default Carb suggestions?
New to this forum, Have a 68 Fastback with a 289, just rebuilt with a 302 crank, roller rockers, cam, heads ported and polished, moving from a factory 2 bbl to a 4. Getting an Edelbrock dual plane intake and looking for suggestions on a new carb. Want a nice driver with some punch but with a decent idle is my goal.
What are folks running that they are happy with?
Old Sep 20, 2009 | 05:04 PM
67mustang302's Avatar
67mustang302
Quick Fuel if you are actually going to tune it completely.
Old Sep 20, 2009 | 07:11 PM
paulford8's Avatar
paulford8
I went from a 2v to a 4v with a basic Holley 4160 600CFM. Took some tinkering/tuning but she is running pretty dang good. Next time I upgrade I will probably look at the Street Avengers as I keep hearing they are a great all around carb that is easy to tune.
Old Sep 20, 2009 | 09:26 PM
68stanger's Avatar
68stanger
What is the advantage/disadvantages of mechanical or vacuum secondaries for my application?
Old Sep 21, 2009 | 04:41 PM
paulford8's Avatar
paulford8
What transmission? Generally vacuum secondaries are more automatic friendly, and generally considered a good street carb. Racers seem to want mechanical secondaries... Not sure about all the reasons why, but 1 is that second set of barrels opens up just a bit faster on the mechs.
Old Sep 24, 2009 | 09:27 PM
68stanger's Avatar
68stanger
Have a top loader 4 speed, so mechanical might be better?
Old Sep 25, 2009 | 02:53 PM
GreyStang's Avatar
GreyStang
Are you going to take the car to the drag strip a LOT? If not, get vaccum secondaries
Old Sep 26, 2009 | 07:38 AM
paulford8's Avatar
paulford8
I am using a vacuum sec Holley 4160 with mine and I have an SROD 4 speed which is very similar to the top loader. It is working good for me! That said I only chose this set up because they guy I bought my intake off of threw it in for free.
Old Sep 26, 2009 | 09:18 AM
68stanger's Avatar
68stanger
Thanks for your help, street driving for me so will look for vacuum secondaries.
Old Sep 26, 2009 | 09:56 AM
67mustang302
Mechanical is fine with a manual, even on the street. The secondaries won't open unless you bury your foot in the accelerator, so you only run on the 2 front barrels all the time. With a vacuum under part throttle moderate load acceleration the secondaries will sometimes open. And tuning a mechanical for throttle response is easier, since you have a second accelerator pump. Sometimes on a vacuum you have to slow the secondaries opening to prevent a bog and cost yourself a bit of performance.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
