tirerack.com
Old Jul 12, 2005 | 07:16 PM
dave86's Avatar
dave86
Default tirerack.com
tirerack.com says my car can take 245/40/18 on the front and 285/35/18 on the rear. it's a 98gt. does that sound good on 18x9 and 18x10 saleen wheels? 285 seems a little too big to me. wouldn't that rub against the fenders?
Old Jul 12, 2005 | 07:17 PM
blueangelfightr's Avatar
blueangelfightr
Default RE: tirerack.com
Nope. That sounds good to me. But spacers wouldn't hurt.
Old Jul 12, 2005 | 07:20 PM
dave86's Avatar
dave86
if i put spacers on, would the tires stick out past the fenders? i see civics with wheels sticking out way past the fenders all the time and it looks like crap.
Old Jul 12, 2005 | 07:58 PM
blueangelfightr
No. Don't get spacers that big.
Old Jul 13, 2005 | 12:49 PM
dave86's Avatar
dave86
Someone just told me that if I have different tire sizes on front/rear, that I can't get my tires rotated. Is this right?
Old Jul 13, 2005 | 04:22 PM
NewMexMustang's Avatar
NewMexMustang
Well techinically you can, but if you have bigger tires on back, then you'll look silly rotating those to the front and small ones on back. So I think that's why he said you can't...right?
Old Jul 13, 2005 | 08:05 PM
mmoto68's Avatar
mmoto68
You shouldn't need spacers.
If your getting Saleen wheels, you should call them with fitment questions. I can't imagine that they would make a wheel that you need spacers for.
I have a '95 with 17x9" Cobra R wheels, 275-40's, and Saleen constant rate springs.
It's a little tight in the front, but I only rub a little at full lock if I push it. I think you could go a little bigger than 245's in the front.
I've got plenty of room in the rear, I've also seen a similar car with the same wheels with 315's in the back that looked fine.
With unidirectional tires, you shouldn't rotate tires from left to right or visa versa. This leaves rotating front to rear. No big deal, just replace the fronts or rears as they wear out. You just have to decide if the 315's are worth it. Do you want car guys to look at your car and go "WHOA!"?
808muscle
12
Nov 22, 2009 12:35 PM
IN2FORD
May 13, 2008 05:22 PM
baddog671
Wheels & Tires
Mar 13, 2008 11:23 AM
laserred02
Apr 13, 2007 12:11 AM
