80mm C&L
Old Apr 13, 2003 | 08:37 PM
MastyrLock's Avatar
MastyrLock
Default 80mm C&L
The 80mm MAF From C&L i put on my 2000GT worked great. I could really feel the power.
Old Apr 26, 2003 | 01:51 AM
Sean's Avatar
Sean
Default 80mm C&L
Power is great! are you experiencing any drivability problems when not at WOT,like stumbling at certain RPMs.
Old Jun 17, 2003 | 01:24 AM
Fordgasm's Avatar
Fordgasm
Default 80mm C&L
i just put a 76mm C&L on my 89 5.0 with 24 lbs injectors and its seems if i go to the floor it takes a second to clear out. its like its getting too much gas or not enough gas. i guessthis would fall into the stumling catogory.
Old Jun 17, 2003 | 01:46 AM
Sean's Avatar
Sean
Default 80mm C&L
What about partial throttle Fordgasm?Just resting my foot on the gas at about around 2500 to 3000 it will occasionally buck,but not all of the time.I have heard of other driveabilty problems similar from others who have used C&L.
Old Jun 30, 2003 | 07:49 PM
Fordgasm's Avatar
Fordgasm
Default 80mm C&L
not really it only does it when i go to the floor, it seems like it takes 2-3 seconds to clear out and then it willgo up smoothly. it could be my fuel pressure i realy havent taken the time to adjust things and see if it will clear up.
Old Jul 20, 2003 | 12:45 AM
vfast's Avatar
vfast
I ♥ Acer
Default 80mm C&L
fordgasp...do you have the right sample tube for the injectors and the size of the mass check their web site to be sure ..if it's ok clock the maf you be good to go
Old Nov 23, 2003 | 05:34 AM
tyybo's Avatar
tyybo
Default 80mm C&L
So when you put in a MAF then what do you do to mess with the fuel intake?</P>
Old Feb 17, 2004 | 01:57 AM
beezy's Avatar
beezy
Default RE: 80mm C&L
What is a sample tube?
Old Feb 17, 2004 | 06:50 PM
vfast's Avatar
vfast
I ♥ Acer
ALIBRATION TUBE CHART
73mm Unit for 1986-1993 Mustangs (with factory A9L Style Processors)
Std 19lb Calibration Clear Tube (101)
24lb Fuel Injectors Blue Tube (102)
30lb Fuel Injectors Red Tube (103)
36/38lb Fuel Injectors Green Tube (104)
73mm Unit for 1993 Cobra Mustang
Std Fuel Injector (24lb) Black Tube (105)
Std Fuel Injectors with Supercharger Clear Tube (101)
30lb Fuel Injectors Blue Tube (102)
36/38lb Fuel Injectors Red Tube (103)
42lb Fuel Injectors Green Tube (104)
Ford Taurus SHO, 73mm Unit
1994-1995 Mustang 5.0, 73mm Unit
Std Fuel Injector (GT-19, Cobra-24) Gold Tube (096)
GT 24lb & Cobra 30lb Injectors Orange Tube (097)
GT 30lb & Cobra 38lb Injectors Purple Tube (099)
GT 36/38lb Injectors & Cobra 42lb Injectors Red Tube (103)
Ford Thunderbird SC 73mm Unit
Std Fuel Injector (30 for 89-93), (36 for 94-95) Clear Tube (101)
36lb Injector (89-93 processor) Blue Tube (102)
42lb Injectors (89-93 processor) Red Tube (103)
(Upgrade injectors may cause computer issues with factory ECM on 1994-1995 Super Coupes)
76mm Unit on 1986-1993 5.0 Mustangs
19lb Injectors Gold Tube (096)
24lb Injectors Blue Tube (102)
30lb Injectors Purple Tube (099)
38lb Injectors Red Tube (103)
42lb Injectors Green Tube (104)
1993 Cobra (24lb) Clear Tube (101)
80mm Unit for 1986-1993 5.0 Mustangs
36/38lb Injectors Blue Tube (102)
80mm Unit for 1996-1998 4.6L Mustangs
GT 19lb, Cobra 24lb Blue Tube (102)
Supercharged (Centrifugal kit)* Clear Tube (101)
24lb GT, 30lb Cobra Purple Tube (099)
30lb GT, 36/38lb Cobra Red Tube (103)
*Also for use with supercharged kits that come with custom computer Mod & injectors
80mm Unit for 1999-2001 4.6L Mustangs
Stock Injectors (GT & Cobra) Black Tube (105)
24lb GT Purple Tube (099)
30lb GT Red Tube (103)
Ford 4.6L Thunderbird, 73mm Unit
Std Injectors (19lb) Clear Tube (101)
1994-1995 Mustang 5.0, 76mm Unit
Stock Injectors GT & Cobra .650 Tube (094)
GT 24lb and Cobra 30lb Black Tube (105)
GT 30lb and Cobra 36/38lb Brown Tube (095)
GT 36/38lb and Cobra 42lb Red Tube (103)
Ford Thunderbird SC, 76mm Unit
Std Fuel Injectors Gold Tube (096)
36-38lb Injectors (89-93) Orange Tube (097)
42lb Injectors (89-93) Purple Tube (099)
Old Feb 21, 2004 | 12:58 AM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
Call C&L and get the right tube for your injectors. Will cost you a few bucks.
