1995 Transmission Interchange Options?
Old Dec 25, 2009 | 10:36 AM
1956_4x4's Avatar
1956_4x4
Default 1995 Transmission Interchange Options?
My daughter has a 1995 Mustang that is going to need another transmission. The car has the 3.8 V-6 engine and is a simple daily driver, so I want to stick with the same AODE transmission. I need to know what other year/model Ford vehicles will have a transmission that would be a direct swap as a replacement.
William Smith
Master Automotive ASE
Master Med/Hvy Truck ASE
Master Emergency Vehicle Technician
Old Dec 25, 2009 | 09:48 PM
a_penquin's Avatar
a_penquin
I would think any AODE would work from 94-04 (minus 5.0 94-96) but you can check part numbers with the dealer, summitracing, or a salvage yard. Salvage yards will definably have the interchangeability books
Old Dec 25, 2009 | 10:00 PM
USMC1775's Avatar
USMC1775
Might be best to rebuild the unit you have, its cheaper, and overall not that difficult. I managed, and only have the training by trial and error in my garage at home
Old Dec 27, 2009 | 12:02 PM
1956_4x4's Avatar
1956_4x4
Is the bolt pattern for the bellhousing on a 5.0 the same as a 3.8? Is there any difference in the transmission behind these two engines? I may have found one, but it's in an Explorer.
William Smith
Old Dec 29, 2009 | 04:04 AM
1956_4x4's Avatar
1956_4x4
Default Will an AODE behind a 95 4.6 fit the 95 3.8?
Think I found one, but as you can tell I'm not up on the Ford interchange items. Will an AODE behind a 95 4.6 fit the 95 3.8? I found one in a 95 Merc.
William Smith
4cylinderplus2
Oct 9, 2020 07:45 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
ChampInSD
Oct 2, 2015 04:55 AM
wraith777
Sep 28, 2015 10:49 AM
