which engine to buy?!?!?
Old Dec 31, 2009 | 10:59 PM
darkngtz's Avatar
darkngtz
Default which engine to buy?!?!?
ok so i wanna buy a new engine for a project im working on. i cant decide if i wanna buy an 03-04 cobra engine or wait for the "coyote" engine. which do you think would better? also how much taller is the 03 cobra engine than the stock cobra engine form the 96-01 model cobras?
Old Jan 2, 2010 | 03:26 PM
67mustang302's Avatar
67mustang302
I imagine the Cobra engine will be a bit taller maybe, but also a bit wider, since DOHC heads occupy more space than SOHC heads. Personally, I'd wait for the Coyote, a DOHC 5.0...it's already bigger to start with, AND it has the advantage in head design of nearly a decade more of development. It's based off the 5.0 "Cammer" Grand Am engine, which makes quite a bit of power without turning insane rpm.
Old Jan 3, 2010 | 05:30 PM
darkngtz's Avatar
darkngtz
hmmm...what do u think the crate price of that engine will be?
Old Jan 3, 2010 | 05:43 PM
67mustang302
Not cheap, especially for the first few years until enough of them get out there as production engines. The 3V for instance wasn't a cheap crate engine at first, but now they're around half the price of what they were a few years ago.
The current 5.0 Cammer(keep in mind though it's a Grand Am legal crate engine) is around $15,000 WITHOUT engine management or wiring.
It's going to be a sophisticated engine, a DOHC 5.0 with variable valve timing is no joke.
Old Jan 3, 2010 | 08:42 PM
Roushstang07's Avatar
Roushstang07
OP Is the Cobra in your sig yours? If anything Id go with another 4.6L Maybe even talk with Lethal Performance and get their Boss330 Racing 4.6L they have for 4G. Or if you wanted to you can get a aluminator block.
5.0 you be at a disadvantage at this point, no one really knows what it be capable of, and besides that its got VVTI, and that alone could cause an issue with engine management, you could either A. Find a way to get your ECM to communicate with it, or B. try and lock out the VVT all to begin with, you may need a stand alone to do so
What are your plans for the engine? Turbo? Twin Turbo?
Old Jan 3, 2010 | 11:27 PM
BruceH's Avatar
BruceH
Old Jan 4, 2010 | 01:04 AM
Fobra's Avatar
Fobra
Banned
for a "project", you should look into a 5.4 or a larger displacement Ford or Chevy motor
squishbang
Jan 26, 2016 04:58 PM
movielover40
Aug 27, 2015 10:13 PM
dba Brakes
Aug 23, 2015 08:16 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
