Basic Fox Body Brake Questions
Old Jan 11, 2010 | 01:40 AM
Everyones Hero's Avatar
Everyones Hero
Default Basic Fox Body Brake Questions
I have an '86 GT & the brake pedal is very soft or "squishy" & braking doesn't seem very solid compared to my old civic.
I know the shoes are pretty much shot so I'm going to replace those first. Is there a certain brand that's better than others or would I be fine just going to Advance Auto & picking up a set from them?
I want to bleed the brakes but I wanted to check to see if it would be alright to use DOT 4 brake fluid (already have it in the garage). Someone awhile back told me that something could happen if you mixed 3 & 4. True or false?
On the civic I ran Brembo blanks & an OE spec pad & they were great. Are Brembos any good for the Fox bodies? If not what would you recommend as a rotor & pad? The reason I ask is because I found Brembos for $24/rotor for the Fox vs the $50/rotor I paid for the civic.
Not really interested in a rear disc swap, just want to get some basic maintenance done & get the right parts the first time around.
Thanks,
-Nick
Old Jan 11, 2010 | 02:54 AM
rex90lx's Avatar
rex90lx
thats all i run on all my stangs in past just house brand shoes just make sure you adjust them if not pedal will be alil soft as far as dot 4 i wouldnt recommend mixing and the rotors should be fine with brembo if want more effective stopping slotted and drilled is way to go
Old Jan 11, 2010 | 03:08 AM
Everyones Hero
Thanks a lot for the reply.
I'll probably have my little brother do the shoes & a front end alignment for me at his tech center & I'll pick up some DOT 3 when I go to get the shoes. Is there any special adjustment for them or is it just like any other drum brake?
I had the blanks on my civic because they said drilled/slotted weren't necessary for a street application. From my understanding the slots/holes are to allow gasses to escape from between the rotor & pad under hard braking conditions.
Hopefully I'll get some more input as to what a good rotor/pad combo is for daily driving.
Old Jan 13, 2010 | 07:46 PM
Jfsram's Avatar
Jfsram
For normal driving slotted and/or drilled will not help with a soft pedal.
The first move towards ridding of a soft pedal is bleeding the brakes.
On a 25 year old car. I'd automatically call for new flex lines too.
As for using the DOT 4 in your garage. Brake fluid that has been opened and stored is not something that I'd pour into a car that I'm having problems with.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Sep 16, 2015 02:11 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
stormesixx
Aug 25, 2015 09:11 AM
cema93
Aug 10, 2015 09:35 PM
