I Need Help
Old Jul 24, 2005 | 04:55 PM
GodZilla37's Avatar
GodZilla37
Default I Need Help
my turn signals stopped working when i started it today. checked the fuses all fine but i turn my key halfway they work and the engine light gas light in the lower right area of the console work when i turn it all the way they dont. i took it all apart and slide the key shaft thingy out and it looks to be ok. would i just have to change that part to solve the problem or can anyone suggest somthing.
would maybe this be the ignition switch.
Old Jul 24, 2005 | 06:42 PM
Chopper's Avatar
Chopper
Default RE: I Need Help
Try turning on the hazard flashers.If they work then I would look at the switch.
Old Jul 24, 2005 | 10:41 PM
99saleen351r's Avatar
99saleen351r
Are you sure its not the flasher??Thats what you look at first not fuses
