Ignition/Electrical problem?
Old Mar 8, 2010 | 07:26 AM
cypher77's Avatar
cypher77
Default Ignition/Electrical problem?
I have a 97 with a V6. It started having a problem starting off and on. It will start fine, you can drive wherever, stop, and then go back to start it and you go to turn the ignition and get nothing. The inside light won't come on or will be very dim and the door bell ding is distorted if it even dings at all. Wait 10 or 15 minutes and it will start right up sometimes, sometimes not. Im 100% sure the battery is good and I have tried wiggling the terminal cables to no avail. I'm guessing it is a wire of some sort bad or maybe the ignition going bad? Any suggestions on where to start? Any help is appreciated.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
