How Do you remove roof side moulding?
Old Mar 17, 2010 | 06:21 AM
frdracfan's Avatar
frdracfan
Default How Do you remove roof side moulding?
Ok I cracked the cowl vent panel on my 2000 so i need one of those but do you have to remove the roof side mouldings to install the new one. I cracked the old one because the moulding covers the panel a little. Any help on installing the new panel would be helpful.
Thanks
Old Mar 17, 2010 | 10:36 AM
frdracfan's Avatar
frdracfan
I think it may clip in but I need to know for sure. Can anybody verify this.
Old Mar 17, 2010 | 06:06 PM
Detailer_Dave's Avatar
Detailer_Dave
Mine might be a bit different being a 95, but I removed the cowl vent to fix the windshield washer nozzle. Open the hood, and the gasket/seal at the back of the hood, on the cowl comes right off. There are what looks like 2 phillips screws under the gasket. They are plastic push clips. I popped them out, and pulled up on the cowl vent at the windshield glass. It wasnt hard to do. I didnt remove anything else except the windshield wiper arms. Once the cowl is unsnapped, it has plenty of flex to come out from under the roof moldings.
Old Mar 17, 2010 | 06:29 PM
03gt04mach1's Avatar
03gt04mach1
I changed it on my '03 GT. Open the hood and take all the fasteners on the firewall out. Take a wide putty knife and pry up on the panel. Put a rag or a towel under it, so you don't damage the windshield. Watch out also for the Washer Tubes too. When I put in the new one,(it was 165.00 at the dealer)I didn't loosen the side pillers. I think they're 5/16s not sure. You have to open the doors, and they sit behind the mirrors. I just bowed the panel, and pulled on the side pillers a little, to get the panel behind it, then put the fasteners back in. But, if I were to do it again, I would take those screws out. Hope this helps.......If you try to put in a used one, take out the piller screws, don't try bowing the panel. Only if it is new, because it's flexible. They harden over time.
Big Al's 03
Sep 16, 2015 07:31 PM
2k232
Sep 16, 2015 10:28 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
wawagner82
Sep 13, 2015 09:02 AM
Sep 10, 2015 08:39 PM
