Need help installing some LED's
Old Mar 21, 2010 | 04:30 PM
Sikshotkilla's Avatar
Sikshotkilla
Default Need help installing some LED's
I have a couple of LED strips I'm going to put in, problem is that I want them to only turn on with the dome lights when I open the car doors. Does anybody know what wire I need to splice into to connect the LED power supplies?
Old Mar 21, 2010 | 08:16 PM
MU71L4710N's Avatar
MU71L4710N
the fuse box under your steering wheel you can probably tap off of. its the second row from the engine bay, a 10 amp fuse and i forget what side its on but you can start pulling them until the dome lights go off then go from there.
Old Mar 22, 2010 | 07:40 AM
Sikshotkilla
oh alright...I'll start there...Thanks
Old Mar 22, 2010 | 12:54 PM
MU71L4710N's Avatar
MU71L4710N
sorry forgot to say and grab one of those fuse taps should be able to get one at an audio store or you could fabricate your own. if you don't know what im talking about its basically a small spade with a wire, you pull the fuse out, hold the spade next to 1 of the metal prongs on the fuse, and re-insert the fuse with the spade held next to it.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
