8.8 i.d tag
Old Jul 31, 2005 | 11:00 PM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default 8.8 i.d tag
i just got a 8.8 rear..with disk brakes and it has 5 lugs...he said it was from a 93 coupe..???????i could not pass it up..for $75.00 it is a traction lock with 3.27 gears...i have the tag but i would like to know what it came from for sure...the numebr are...
421e
3sl27a88 6c04 any help will be great
Old Aug 2, 2005 | 12:15 AM
99saleen351r's Avatar
99saleen351r
Default RE: 8.8 i.d tag
Well it didnt come from a stang with disc brakes and 5 lug thats for sure.Some one probably got it for the gears and disc brakes and put it in the 93 coupe.If i was betting i'd say its from an LSC.As long as it bolts in why would you care were it came from??
Edit: That was a killer deal even if it needs a rebuild.you should throw some new bushings in the rear while you have it out.There fairly cheap depending on what you get ranging from 40 on up
Old Aug 2, 2005 | 12:56 AM
5.0mustang5speed
I ♥ Acer
i dont care what it came from..i was just wondering..also i though i may came from a 94 stang..they had 5 lugs and some had disk brakes...also the 93 cobra came with 5 lugs and disk brakes...they are huge...is there any difference in the lsc and the stang rear..width wise..????
Old Aug 2, 2005 | 12:57 AM
5.0mustang5speed
I ♥ Acer
also..i just noticed that the upper control arms look longer..and the are both slighly curved..
Old Aug 2, 2005 | 01:27 AM
327t5werebear's Avatar
327t5werebear
to tell u truthfully i can't be sure but it sounds like the guy got the the 5-lug + disk conversion for the fox body mustangs... 3.27 gears are stock for the 93's and if he had the money to do a $2k upgrade like lugs and disks he prolly had the cash in the sofa for a 9" rear end that he can purchase pre-customized with the same lugs and brakes and the rear end he sold u... good job on yer good buy... a junk yard stock rear end assembly runs round $200... imo: Killer Score Bro !!!
Old Aug 2, 2005 | 01:52 AM
5.0mustang5speed
I ♥ Acer
i will use it no matter what...i will measure the width tomorrow and compare it to the 7.5 rear under the car...
Matt's 95 Stang
Oct 5, 2015 07:16 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
67LimeCoupe
Sep 2, 2015 08:02 AM
bigdaddy51200
Aug 19, 2015 05:09 AM
