1996 5.0/3.8 engine swap
Old Apr 19, 2010 | 08:08 AM
Bobx44's Avatar
Bobx44
Default 1996 5.0/3.8 engine swap
Ive got a 96 convert. with a 3.8 that recently blew up and Im wanting to drop in a 5.0/auto in it, Im gettin rid of all the computers and going carburated. I know I need to change out the rear end and the radiator and add a fuel pressure reg. The 5.0 is the complete package from a early 90's (90-93) cobra (motor mounts, power steering, air conditioning etc. etc.) but it wont stay stock, anyone see any other problems other than the rearend?
Old Apr 19, 2010 | 09:08 AM
LilRoush's Avatar
LilRoush
There is a LOT more you need to swap out to make it work right. Get in the V6 section and do a quick search, you'll see what I mean. Front suspension, gauge cluster and many other things need to be considered.
Old Apr 19, 2010 | 10:17 AM
Bobx44's Avatar
Bobx44
Well... I just got off the phone with Ford Proformance Tech and they said, again just change the rear end, which I found a 8.8 out of a 96' for 225$ and the radiator. the guy said that the 95's had the 4.9l and the front end should hold up, and that I wouldnt have to worry about the K member or anything else.. they should know shouldnt they? lol and why the gauge cluster?
Old Apr 19, 2010 | 04:51 PM
LilRoush's Avatar
LilRoush
4.9L huh? Nice.
The front shocks and springs are different between the V6 and V8 for weight reasons, you'll want to upgrade to the GT spec. V6 K member changed from the 94/95 V6 and the 96-98. Make sure you get the right motor mounts to put a 302 in the newer K member. You'll want a larger fuel pump and related as well.
Gauge cluster for V6 and V8 are different.
Going carb saves you a lot of headache, but at the same time, removing all the stock emissions stuff and putting in an older motor is illegal on a street car... I'm just throwing that out there.
Old Apr 19, 2010 | 05:17 PM
Bobx44's Avatar
Bobx44
Ive got the motor mounts still on the 302 from the old car. I mean the 302 and trans was given to me and its just sitting in the floor of the shop, so when this 3.8 blew I figured I might as well just use that 302 and clear up some room and make my car run a lil better.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
