trans fluid in the braking system?
Old Apr 27, 2010 | 08:30 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default trans fluid in the braking system?
guy i work with just bought a rodeo and found out instead of brake fluid, it has transmission fluid in it....
he took it to monroe to ask them to diagnose why his caliper is locking up, and they said it was the fluid
they wanted $1200 to replace the master cylinder, all the brake lines, and the calipers.
is this necessary? would trans fluid harm any of that stuff? i know brake fluid is more harsh than trans fluid so it didnt make sense...
could he flush all the trans fluid out and replace the caliper and be good to go?
Old Apr 27, 2010 | 08:46 AM
Detailer_Dave's Avatar
Detailer_Dave
trans fluid has the possibility of swelling the seals. I would flush the system, at minimum, and replace the caliper. You will know if any other damage has been done. The worst case would be to replace M/C, flex lines, calipers, and any other part of system that has seals.
Old Apr 27, 2010 | 09:14 AM
99BlackPonyGT
ok thanks...we have a parts truck here with a complete brake system, may just pull all the stuff off it and see where we end up
thanks for the prompt responce
mtgldr
Feb 3, 2024 09:00 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
Sep 8, 2015 11:50 AM
