Question about gears..
Old May 28, 2010 | 11:51 AM
trailor's Avatar
trailor
Default Question about gears..
ok so me and a buddy were having a discussion about gears last night, and he said that when going from, for example, 3.27's to 4.10's, your car will read higher rwhp. now he's not claiming that they actually increase engine horsepower, just that they reduce horsepower loss to the wheels, which gives you a higher rating on the dyno. i disagreed, but didn't have much to base my argument on. so i was wondering if any of you can testify on his behalf, or my behalf, and put this argument to rest. proof (dyno #'s, etc.) would be best. thanks guys!
Old May 31, 2010 | 05:08 PM
MADMADVIC's Avatar
MADMADVIC
DOES NOT HELP HORSEPOWER,BUT HELPS RPM TO COME UP FASTER..I WENT FROM 3.08 TO 4.30 NO HP GAIN BUT MAN ALIVE SHE SPINS UP QUICKER..
Old May 31, 2010 | 09:11 PM
GreyStang's Avatar
GreyStang
Put it this way.. You can get the same basic effect of lower rear gears by putting on smaller diameter tires on the rear wheels,, that will lower the effective final ratio probably not a lot but noticeable.
So does THAT increase actual HP somehow? Umm nope
You're trading top speed for acceleration, simple as that
Old May 31, 2010 | 09:57 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Your friend is a idiot.
Old May 31, 2010 | 11:48 PM
99GTvert's Avatar
99GTvert
is my username.
Gear'ed cars read a little differently on the dyno (than stock cars) because that 1:1 ratio is changed ever so slightly. Bigger gears read a little less.
Old Jun 1, 2010 | 12:45 PM
trailor's Avatar
trailor
yeah thats what he said. however, when you say "bigger" gears read less, are you saying that 4.10s will read less HP than 3.27s? i only ask bc technically 3.27s are "bigger" than 4.10s
Old Jun 1, 2010 | 01:33 PM
Soldier GT's Avatar
Soldier GT
That about sums it up...
Old Jun 1, 2010 | 04:32 PM
GreyStang's Avatar
GreyStang
Your friend is trying to suggest there is less frictional drag in a 4.10 gearset than in for example a 3.27, hence "more horsepower" available for the car??
Nope not true. At least not anything more than maybe 1-2 hp difference
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
