AOD with wrong fluid :O
Old Jun 16, 2010 | 08:35 PM
8v-of-fury's Avatar
8v-of-fury
Default AOD with wrong fluid :O
Hi all, I have what I believe to be an 87 AOD trans in a 1967 Cougar.. I think I put a liter or two of Type F in it when it was low last (before I knew it needed Mercon.. )
Now from what I have read I can drain 2/3 of the fluid by dropping the pan alone.. the other 1/3 will be trapped in the torque converter.. If I do this and fill it back up with Mercon then there shouldn't be more than %7-8 of type f left in the mix right? Or is there a drain plug on the AOD converter?? I think I may have read somewhere that there is.
The car has not been driven more than 5 miles since this was added, so i am hoping ZERO damage was done
TIA GUYS!
8v
Old Jun 17, 2010 | 10:08 AM
8v-of-fury's Avatar
8v-of-fury
Does anyone know if there is a drain plug on the AOD torque converter?
Also I have heard rumor they take 12qts to fill back up?
Thunderball
15
Nov 22, 2015 11:49 PM
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:42 PM
