Need Some Advice
Old Nov 27, 2003 | 06:13 AM
35thblacktang's Avatar
35thblacktang
Default Need Some Advice
I own a black 99 GT 35 anniversary...5 speed....i was wondering if anyone could give some advice on how i could squeeze some horsepower out of my ride.....the only aftermarket stuff i have is the k&n filter with pro performance air kit.....any suggestions would be greatly appreciated.
Old Nov 27, 2003 | 10:04 PM
03WhiteGT's Avatar
03WhiteGT
I'd get an exhaust ..headers,x pipe, catback first
Old Nov 28, 2003 | 01:06 AM
67aquafastback's Avatar
67aquafastback
Bigger TB and larger injectors and higher out put fuel pump.
Old Nov 28, 2003 | 03:39 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
</P>
i wouldnt do any of those unless i was running boost except maybe a 70mm tb and i would only do that if there was almost nothing left to do NA</P>
Old Nov 28, 2003 | 04:04 AM
95Stealth302's Avatar
95Stealth302
Ignition, MAF, full exhaust, Gears, shifter - way better but no hp help, little stuff that you can do like timing, new plugs and wires.</P>
Going deeper, get some PI heads, intake manifold, TB, injectors, fuel pump/regulator, new clutch.</P>
Old Nov 28, 2003 | 03:32 PM
03WhiteGT's Avatar
03WhiteGT
what would new plugs and wires do???
Old Dec 2, 2003 | 06:25 AM
IDrive01Mustang's Avatar
IDrive01Mustang
yeah a larger throttle body, headers, cat-back exhaust will give u a nice gain <IMG src=smileys/smiley1.gif border="0">and than maybe a cat-delete pipe/test pipe or a hi-flo cat.
Old Dec 2, 2003 | 12:06 PM
Dan04COBRA's Avatar
Dan04COBRA
</P>
Nothing, even if you upgraded your ignition, what you have now is fine.</P>
Old Dec 2, 2003 | 02:45 PM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
engine=air pump more air in more air out more power..</P>
mass air with tb and upper plen.... plus headers, x pipe and good mufflers and you could see 35 hp or possible more </P>
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
