rear end howling help
Old Jul 10, 2010 | 01:57 PM
ctgreddy's Avatar
ctgreddy
Default rear end howling help
'02 mustang gt 8.8 rear with 3.73's and 31 spline diff/axles. just put the diff and axles in about 2 weeks ago, all was good. now it's making a howling noise, sounds kind of like a wheel bearing, when you turn right it goes away, so my first thought is a wheel bearing, might of got damaged when we slid the axles in or something. but the weird thing is that it's not constant. when you let out of the gas, or when you get on the gas, the sound goes away. it's only there when you're constant on the gas, like going 55 down the highway. also it's only when you're doing over 40. so i'm thinking either a wheel bearing or a side bearing on the diff. any suggestions?
Old Jul 11, 2010 | 03:43 PM
bigjohnstud4200's Avatar
bigjohnstud4200
did you use friction modifier? were you gears ford racing or aftermarket?
Old Jul 11, 2010 | 03:46 PM
bigjohnstud4200
Originally Posted by bigjohnstud4200
did you use friction modifier? are your gears ford racing or aftermarket?
correction..
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
