Are these the same?
Old Aug 10, 2005 | 02:16 AM
Stang9946's Avatar
Stang9946
Default Are these the same?
Stupid question I think...and maybe not even in the right board but......is a stall converter and a torque converter the same thing??
Old Aug 10, 2005 | 09:12 AM
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
Default RE: Are these the same?
A stall converter is a performance version of a torque converter. Basically, it enables your engine to reach higher rpm (and torque) before the transmission shifts.
Old Aug 10, 2005 | 09:46 PM
4600cc's Avatar
4600cc
I ♥ Acer
I don't think that last one is correct. Transmission shifts are made using on board electronics or in tranny hydrolics. Torque converter's stall speed is when torque converter locks up and goes 1:1, ending the slipping. Somewhat similar to when your clutch is hoocked up. Right? Wrong?
AL
Old Aug 10, 2005 | 09:47 PM
99saleen351r's Avatar
99saleen351r
Nooooo.....A stall lets your motor rev higher before it moves,So you can launch at say 3600 rpms off the line. It doesnt have anything to do with shifting.All it is is alot looser than the stock one and trannys will acually shift softer cause the converter is so loose it sucks up the hard shifting
Old Aug 10, 2005 | 11:22 PM
Stang9946's Avatar
Stang9946
ORIGINAL: 99saleen351r
So you're saying the the stall converter allows you to launch off the line at a higher rpm and have less if not any slip/tire spin? I'm not 100% what you're saying....
