Car dieds after it is hot....once cooled down it starts
Old Oct 15, 2010 | 08:23 AM
94StangGT5.0's Avatar
94StangGT5.0
Default Car dieds after it is hot....once cooled down it starts
Need help......My 94 GT has been in storage for over a year. I just pulled her out and after she is warmed up the car stalls. I have replaced the coil and I have pressure from the fuel pump. The distibutor was real dirty and I cleanned all the contact points up.. The car will start once it cools down. Any help would be great!
Thanks
Old Oct 15, 2010 | 09:55 AM
1ATony's Avatar
1ATony
Former Sponsor
Thanks
If your car has the catalytic convertors on it ,check to see if they're getting red when the car warms up. If they're clogged it would cause your car to stall.
Old Oct 18, 2010 | 01:19 PM
94StangGT5.0
Default still going on
I have replaced the ignition control module and it is still doing this.....any suggestions?
Old Oct 18, 2010 | 11:21 PM
petrock's Avatar
petrock
Sounds like a vacuum leak. Some vacuum lines don't get opened up until the motor is hot. If one has a leak in it it could cause a stall.
Good luck...
Old Oct 18, 2010 | 11:53 PM
stanggurl007's Avatar
stanggurl007
how's your coolant level?
Old Oct 22, 2010 | 02:25 PM
94StangGT5.0
Default Got it!
Replaced the pick up coil....works great!
Old Oct 23, 2010 | 09:21 AM
jsaleen90's Avatar
jsaleen90
I had this issue and it turned out the battery had a bad cell, but it looks like you got it figured out I guess.
Old Oct 23, 2010 | 02:02 PM
stugots's Avatar
stugots
this issue is more and more common all of a sudden on the 94/95's
djbigskrilla
Sep 20, 2022 01:04 AM
cvarner131
Aug 17, 2015 07:38 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
HIS S-197
Aug 10, 2015 05:47 PM
