Please help
Old Jan 7, 2011 | 04:07 PM
tiggerstang's Avatar
tiggerstang
Default Please help
The car starts, it runs fine. But when i drive, it just shuts off. Some times it will start right away, some times it wont. I replaced the fuel pump and relay. It seems like as if some one just shut the key off. Any one possibly know a solution to this issue?
Old Jan 8, 2011 | 03:45 AM
petrock's Avatar
petrock
Bad fuel pump or fuel pump relay won't cause the car to just shut off. It would sputter and then die if it was a fuel problem. I would suspect an electrical problem. Check the battery connections to make sure they are tight etc. If they are corroded, clean them off with some baking soda/water and a wire brush. If the corrosion is down into the cable, then replace the cable. Also have your battery and alternator checked out. Most auto parts stores will do it for free. Good luck...
Old Jan 8, 2011 | 06:45 AM
tiggerstang
Default wont start
when the engine shuts off and i try to restart the engine turns over but will not run could it have something to do with the injectors
Old Jan 8, 2011 | 07:53 AM
a_penquin's Avatar
a_penquin
How long are you driving for? What temp is the engine at when shut down occurs???
Old Jan 8, 2011 | 03:13 PM
95 BLOWN GT's Avatar
95 BLOWN GT
sounds like some kind of electrical problem to me..
Old Jan 8, 2011 | 04:36 PM
tiggerstang
It seems to shut down at any temp. my average temp is about 200-210..I have a griffin alum rad with elect fan
Old Jan 8, 2011 | 08:13 PM
tiggerstang
where is the 10 pin connector ? that someone from another site called the salt&pepper shakers. also said black & white engine electrical connectors can also cause poor idle quality
Old Jan 10, 2011 | 01:31 AM
petrock's Avatar
petrock
Did he also say you should wear an aluminum foil hat to block the aliens from reading your thoughts?
Old Jan 10, 2011 | 03:02 PM
Z28KLR's Avatar
Z28KLR
I had this same problem many years ago with an '88 Escort; it would fire up and run fine for 10 seconds and then die as if you shut it off with the key. Turned out to be a bad pcm.
