scanguage2
Old Jan 30, 2011 | 02:13 AM
muellergt2007's Avatar
muellergt2007
Talking scanguage2
Will a ScanGuage2 work on a tuned GT? The ScanGuage2 has a horsepower guage that is maybe better than a dyno because it plugs into your port. Check it out!
Old Feb 2, 2011 | 08:32 PM
AustinBoston17's Avatar
AustinBoston17
also interested
Old Feb 4, 2011 | 10:36 PM
Z28KLR's Avatar
Z28KLR
That's gotta be complete bs. The only way it would know that is if your car's pcm knew how much power the engine was producing at any given rpm, which it doesn't. Otherwise the aftermarket would have hp gauges to sell you and people would be sporting them in their pods. Chassis dyno's are somewhat subjective and otherwise open to influence, but when set up properly and ran by a good technician they're still about the most reliable source for acquiring hp and torque values.
Old Feb 5, 2011 | 06:12 AM
AustinBoston17
Yes obviously, but does anyone know how to use the instantaneous HP feature on the scanguage2?
Old Feb 5, 2011 | 05:02 PM
muellergt2007
Default website?
I says on the scanguage site that you gotta put in a code or something to get it to read Hp? Do you have a scanguage? If you do could you let the rest of the world know if it is worth the money?
Old Feb 6, 2011 | 10:21 AM
AustinBoston17
I have one, but I dont completely understand how it works. Right now all it reads is my mph and rpms. I havent set up the miles until empty or mpg yet. Trying to see if someone on here has one thats knowledgeable
Old Feb 12, 2011 | 08:02 PM
8lug's Avatar
8lug
I use a scangauge II on my 2005 F350 diesel and 2000 3.8 mustang. It works on any vehicle 1996 or newer equipped with an OBDII port. It has 24 digital gauges you can program into it by going to there web site and getting the codes. It displays 4 gauges at a time. I monitor transmission temps, coolant temps, air intake temps, volts, mpg, and it gives instant horse power readings as you drive. It's also an OBD code reader and you can turn the check engine light off after repairs. It's worth every penny as I have avoided serious engine meltdowns by monitoring the digital gauges over the idiot gauges on the dash. I have seen the coolant temps at the boil over point and the idiot gauge on the dash still reading normal !! It's nice to know the operating temp of the transmission also.
Old Feb 12, 2011 | 08:12 PM
8lug's Avatar
8lug
The code for horse power is TXD= 00, RXF= 400080000000, RXD= 0200, MTH=000A00240000
Old Feb 13, 2011 | 07:51 PM
AustinBoston17
Thanks!
